removing data
1137
08-04-2020 11:46 AM
PhillipSchoettlin
I added some address to a map and there were a couple the geocode feature found multiple.  Two of the alternative addresses are showing as points on my map and I can't remove them - even after I removed the table of addresses I had added to begin with.
The A with the bright Blue circle and the B in the Yellow circle are unwanted.
Phil
LukasFalk
Hey Phillip,
In attempt to look into your issue I opened the aprx in the folder you attached and found the source data was not included.  If you could upload a gdb containing the data in question I'd be happy to look into it further.
Deleting point features from the map should be pretty straight forward.  Below I've included some links containing documentation outlining what this process looks like.  There are multiple ways to go about this.
Delete features and parts of features—ArcGIS Pro | Documentation
Delete Features (Data Management)—ArcGIS Pro | Documentation
I hope this helps!
Lukas
PhillipSchoettlin
Lukas, I tried to respond directly to you.  Here is the screen capture. the A & B are the points I can't delete.  I used the edit > select > delete function, but I can't get points to move.  Even if I turn off all the other layers, they are still there.
The red points are where Boy Scouts live.  We are working with the district to look at how we should recruit new scouts.
Thanks for your help.
LukasFalk
Hello Phillip,
Have you tried deleting the features within the attribute table?  If that doesn't work, a simple workaround would be to select all the features except for those two points, then exporting those selected features to a new layer.  Let me know how that goes for you!
Lukas
