How to separate a polygon shapefile into multiple shapefiles based on an attribute
68349
6
06-08-2017 12:56 AM
EllenWildig
I'm looking to break up polygons by an existing attribute,  the feature they were created around, into multiple different shapefiles. However, I'm struggling to find a tool which would achieve this. Is there a simple way to break them apart?
Thanks!
DanPatterson_Retired
Split layer by attributes ... the original.. supposed to be available at all license levels in 10.5, but the link has been used for years and works with old versions as well
EllenWildig
Worked perfectly. Thank you so much!
Ellen could you mark the thread that answered your question correct so that solutions to problems bubble to the top.  Thanks
Arthur_Morgan
I can't find split layer by attributes in ArcGIS 10..8, has the name been changed?
BryanO_Reilly
i think this is what you're looking for
JayantaPoddar
Also attaching the integrated GP tool Split by Attributes - ArcMap, which I guess, got inspired from Dan_Patterson‌'s work.
Think Location
