How to add Labels
1605
5
07-16-2018 07:46 AM
deleted-user-Jhc6Dca2JfQr
Hello All-
I have created a map- both in ARCMAP PRO and 10.6 (trying to learn Pro as I go along) Not sure which one is easier to do this in so I have both open-
The map has a bike path in it perimeter-
   I need to add a labels such as-
      1- start here
      2- Kiosk #1 and so on
      3- Then i need to place mile markers along the 9 mile path-
Do I need to make a layer for the labels ? if so how?
Or do I just drop a label where I need and add text to it?
I added a snip to show a little of what I am doing.
DanPatterson_Retired
that would be done on the layout, not the map
MichaelVolz
Esteemed Contributor
You can add labels on the map in ArcMap, but currently not in Pro, which may or may not make this task easier in ArcMap.
Idea for Pro though:
https://community.esri.com/ideas/10410
If it's currently easier in ArcMap, then when this idea is implemented in Pro (No idea of when) the 2 pieces of software would probably then be equal for this specific task.
This
MichaelVolz
Is this site somewhere in downstate NY?
Yes- Calverton, NY
