How can I auto-connect polygons in ArcGIS 10.3?
7936
14
06-17-2015 01:11 PM
SteveSkotnicki
I am new to ArcGis, and I am creating a large number of adjacent polygons for a geologic map that share edges. How can I connect one polygon to another such that the topology will contain no gaps, and will allow me NOT to have to redraw the shared edge(s)?
Tags (1)
BruceCarroll1
Steve, Yes indeed. That is why I mentioned that the "cut larger polygon" was the most efficient. But sometimes you have to deal with the hand you are dealt (Shapefile  or Geodatabase).
JayHanson
All so you can look into using the "align to shape" to in the Advanced editing tool bar.
SteveSkotnicki
Thanks Jay.
Being new to GIS, and after working on this for about 8 hours, I agree with you that the cut-polygons method is easiest. However, in order for it to work, ALL adjacent polygons must be selected, not just the one I am working on. I have also had success occasionally stopping and using both the polygon tool (for closed isolated polygons) and the Auto-complete Polygon tool for two adjacent polygons not near the edge of the map.
So I am going to consider this question answered. Thanks very much for your help:)
tMarkWilliams
Hi Steve
I just thought I would add, that you could add lines with snapping turned on and then at the end convert Features to Polygons
Hope this helps
Mark
"Bring back the coverage!", (R. West 2002)
SteveSkotnicki
Mark,
That's a good idea. If I do that, do all of the features ned to be lines, or can I later select only the only the lines I want to convert?
