Using OutStatistics with Dynamic Layer
5238
01-06-2015 02:08 AM
LaurentSIBILLE
Hello,
we're trying to get statistics on dynamic layer, but it seems not work.
We always get an empty result while executing the following querytask.
Is there any other way to get statistics on dynamic layer ?
Dim queryTask = New QueryTask(New Uri(String.Concat(Me.CarteView.MapServicePatrimoine.ServiceUri, "/dynamicLayer/99")))
Dim query = New Query("1=1") With {
                .GroupByFieldsForStatistics = myUniqueValueRenderer.Fields,
                .OutStatistics = myUniqueValueRenderer.Fields.
                                    Select(Function(field) New OutStatistic(
        field,
        String.Format("{0}_{1}", StatisticType.Count.GetNom, field),
        StatisticType.Count
                                    ToArray,
                .Source = rendererTaskParameters.Source
Dim queryResult = Await queryTask.ExecuteAsync(query)
Thanks for your answer,
Best Regards.
MichaelBranscomb
Esri Frequent Contributor
In your code example what type is "rendererTaskParameters"?
You should not need to specify the DynamicLayer endpoint in the URL - instead it should be specified via the Source property on the Query class - most likely using the QueryTableDataSource class as the datasource property of a new LayerDataSource instance?
Hopefully this sample should demonstrate the right approach: Code Example - QueryTableDataSource
Cheers
Mike
LaurentSIBILLE
Thanks for your answer.
The QueryTask's constructor needs an URI, so which URI should we specify ?
The DynamicLayer we use is created with a QueryTableDataSource as desmonstrate in the sample.
The "rendererTaskParameters" is a GenerateRendererParameters and the source passed to the QueryTask is a LayerDataSource using the QueryTableDataSource.
Dim queryTableSource = New QueryTableDataSource() With {...}
Dim layerSource = LayerDataSource() With {.DataSource = queryTableSource}
Dim rendererTask = New GenerateRendererTask(Me.CarteView.MapServicePatrimoine.ServiceUri)
Dim rendererTaskParameter = New GenerateRendererParameters() With {
                                            .ClassificationDefinition = classificationDefinition,
                                            .Source = layerSource
Dim rendererTaskResult = Await rendererTask.GenerateRendererAsync(rendererTaskParameter)
Cheers,
Laurent
