Subtypes in runtime Geodatabases
4704
12
08-30-2017 07:42 AM
EdwardBlair
I'm probably missing something, but is there support for subtypes and subtype-specific domains in the runtime Geodatabase?  From what I see if a field has a domain assigned at the class level that domain assignment is respected, but I don't see anything that is aware of a domain assigned at a subtype level.
Any info would be much appreciated.
Ed
JoeHershman
TypeIdFieldName is the field that the service is symbolized.  The above is only valid if symbolized by Subtype, which is not a valid assumption in our case
-Joe
MarkCederholm
Does your feature service have a corresponding map service:  e.g.
  • UES/Field_ESRP (FeatureServer)
  • UES/Field_ESRP (MapServer)
If you substitute "MapServer" for "FeatureServer", you will get the correct info.  If you don't have a corresponding map service, then your only recourse is to upgrade your ArcGIS Server to 10.5.
JoeHershman
I apologize my earlier post had a typo (now corrected).  I was thanking you because the information you provided solved my problem perfectly.  We need the subtype information Name/Code on the client.  We are already generating an offline configuration file using the WebMap json, I simply combine the subtype information from the feature service definition and all is good, less than 10 lines of code
-Joe
