SketchEditor rotation does not allow to set rotation axis point
641
01-12-2022 05:07 AM
jcarlos
I'm using SketchEditor.StartAsync()  to rotate an existing graphic geometry. However, I have a problem because the rotation center changes every time that I rotate the figure. There is any way to select or set the axis of rotation? Or how could I rotate it correctly?
I'm using ArcGISRuntime 100.12.0 in a WPF application with .net framework.
I attach some screenshots of the problem.
I want to rotate this figure:
I rotate it a couple of times:
When I try to return to the origin position, the shape does not match because, in every previous rotation, the axis to the rotation was different.
My code:
try
                AssociatedObject.SketchEditor = new SketchEditor
                    IsEnabled = true
                SketchEditConfiguration sketchConfig = new SketchEditConfiguration()
                AllowRotate = true,
                AllowVertexEditing = false,
                AllowMove = false,
                ResizeMode = SketchResizeMode.None,
                VertexEditMode = SketchVertexEditMode.InteractionEdit,
                RequireSelectionBeforeDrag = false
                SketchCreationMode creationMode = SketchCreationMode.Polygon;
                SketchEditorGeometry = await AssociatedObject.SketchEditor.StartAsync(g.Geometry, creationMode, sketchConfig);
                if (SketchEditorGeometry == null)
                    CancelCurrentActions();
                else
                    // change old geometry.
            catch (Exception ex)
