QueryRelatedFeaturesAsync returns zero results
1022
03-18-2022 09:34 AM
MattH
I've been trying to call QueryRelatedFeaturesAsync to get related features from a feature service, but it's returning zero results. If I call queryRelatedRecords using Rest with the same ObjectID, I correctly get 38 results.
I was actually getting related features returned at some point last week, but it looks like I'm missing something now.
I've tried a few things:
IdentifyLayerResult results = await esriMap.IdentifyLayerAsync(_myFeatureLayer, e.Position, 10, false);
//correct feature is loaded
ArcGISFeature myFeature; = (ArcGISFeature)results.GeoElements[0];
//returns zero results
IReadOnlyList<RelatedFeatureQueryResult> relatedFeaturesResult =
await myFeatureTable.QueryRelatedFeaturesAsync(myFeature);
I tried adding query parameters:
ArcGISFeatureTable myFeatureTable = ArcGISFeatureTable)myFeature.FeatureTable;
//returns the correct relationship info
RelationshipInfo commentsRelationshipInfo = myFeatureTable.LayerInfo.RelationshipInfos.FirstOrDefault();
RelatedQueryParameters relatedQueryParams = new RelatedQueryParameters(commentsRelationshipInfo) { ReturnGeometry = true };
await myFeatureTable.QueryRelatedFeaturesAsync(myFeature, relatedQueryParams);
I also tried force loading the feature table:
await myFeature.LoadAsync();
await myFeature.FeatureTable.LoadAsync();
JoeHershman
I've only ever done with offline tables, but you could try to explicitly load the related tables and see if that helps
var relatedTables = myFeatureTable .GetRelatedTables();
foreach (var relatedTable in relatedTables)
	await relatedTable.LoadAsync();
var relatedFeaturesResult = await myFeatureTable.QueryRelatedFeaturesAsync(myFeature);
-Joe
MattH
Thank you.
That didn't work directly, but it got me to look in the right place.
At some point, I removed my reference to the related feature layer from the map. I didn't realize that the feature table had to be explicitly added to the map to be found by .QueryRelatedFeaturesAsync()
