I've found a bug in the current version (I reckon).
I'm using Esri.ArcGISRuntime.WPF v200.0.0 in a WPF + NET7 application.
I am publishing it as self-contained win-x64.
Accoring to https://developers.arcgis.com/net/license-and-deployment/deployment/#wpf-or-winui-targeting-net-6-or... your DLLs should be copied to the <Output>\publish folder... which they are not.
In fact all the files in <BuildOut>\runtimes\win10-x64\native\ are not copied (i.e. RuntimeCoreNet200_0.dll).
Here's my csproj:
<Project Sdk="Microsoft.NET.Sdk">
<PropertyGroup>
<OutputType>WinExe</OutputType>
<TargetFramework>net7.0-windows10.0.19041.0</TargetFramework>
<Nullable>enable</Nullable>
<ImplicitUsings>disable</ImplicitUsings>
<UseWPF>true</UseWPF>
</PropertyGroup>
<ItemGroup>
<PackageReference Include="Esri.ArcGISRuntime.WPF" Version="200.0.0" />
</ItemGroup>
</Project>
Please let me know if you know about this already and when it will be fixed.
I can copy those DLLs afterwards myself. But if I want to deploy/publish it as single-file I'm out of luck 😞
thx
PS: I've also attached my full Solution for reproduction purposes
Solved! Go to Solution.
Yeah that’s a VS bug. In your project settings add this and it should show:
<RuntimeIdentifiers>win10-x86;win10-x64;win10-arm64</RuntimeIdentifiers>
Or you can manually change it in the publish settings file.
Make sure when you publish to set your runtime identifier to “win10-x64”.
This is a change from 100.x where the RID was “win-x64”.
Side note: v200.1 will generate a helpful build error if you use an unsupported RID so that you’ll realize this a little easier.
I would... if I could... see screenshot
