Problem with Loading Speed When Load the Multiple Local SLPK file
1349
11-08-2021 05:48 AM
KarthikS
I am developing an WPF application that load multiple local SLPK files using ArcGIS Runtime Dot Net SDK.
Each SLPK have buildings, highway roads, vegetations and trees.
I have 64 GB RAM with Good Graphics Card PC.
But still loading speed is very slow.
My code is given below
 Please give us advice
Thanks
MichaelBranscomb
Esri Frequent Contributor
A couple of questions:
  • Are you using ArcGIS Runtime SDK for .NET version 100.12?
  • Can you share the metadata for your SLPKs to check the layer type, version, etc?
A quick way to check the SLPK metadata is to use 7-zip to browse into the SLPK > 3dSceneLayer.json.gz > 3dSceneLayer.json. This contains the layer type, version, texture format, etc.
If your SLPKs are version 1.6 or less then try converting them to 1.7/1.8: https://github.com/Esri/i3s-spec/blob/master/i3s_converter/i3s_converter_ReadMe.md
Also see https://developers.arcgis.com/net/reference/release-notes/100.12/#enhancements
KarthikS
Hi  MichaelBranscomb
Thank you for your reply
Yes, I am using ArcGIS Runtime SDK for .NET version 100.12
My slpk file version is 1.7. I attached the metadata.json, 3dSceneLayer.json and nodepages/0.json files
my all slpk file contains one to two buildings
I Load the 50 slpk file at a time.
Can you share me your email, So I can forward my slpk file and other files
Thanks
KarthikS
MichaelBranscomb
We would love to test your data - please email me on mbranscomb@esri.com.
Thanks
