Offline Sync geodatabase: empty table / feature layer results
2328
11-28-2023 02:30 PM
MoyerSolutions
Hello! I need an offline syncable geodatabase. I am trying to read fields from a geodatabase, but the results are empty.  None of the fields load.
The table has fields, I'd expect to see these headers:
My code is effectively the same as the sample from the ArcGIS.WinUI.Samples.GeodatabaseTransactions
private async Task GetLocalGeodatabase()
    // Get the path to the local geodatabase for this platform (temp directory, for example).
    string localGeodatabasePath = GetGdbPath();
    try
        // See if the geodatabase file is already present.
        if (File.Exists(localGeodatabasePath))
            // If the geodatabase is already available, open it, hide the progress control, and update the message.
            _localGeodatabase = await Geodatabase.OpenAsync(localGeodatabasePath);
            LoadingProgressBar.Visibility = Visibility.Collapsed;
            MessageTextBlock.Text = "Using local geodatabase from '" + _localGeodatabase.Path + "'";
        else
            // Create a new GeodatabaseSyncTask with the uri of the feature server to pull from.
            Uri uri = new Uri(SyncServiceUrl);
            GeodatabaseSyncTask gdbTask = await GeodatabaseSyncTask.CreateAsync(uri);
            // Create parameters for the task: layers and extent to include, out spatial reference, and sync model.
            GenerateGeodatabaseParameters gdbParams = await gdbTask.CreateDefaultGenerateGeodatabaseParametersAsync(_extent);
            gdbParams.OutSpatialReference = MyMapView.SpatialReference;
            gdbParams.SyncModel = SyncModel.Layer;
            gdbParams.LayerOptions.Clear();
            gdbParams.LayerOptions.Add(new GenerateLayerOption(0));
            gdbParams.LayerOptions.Add(new GenerateLayerOption(1));
            // Create a geodatabase job that generates the geodatabase.
            GenerateGeodatabaseJob generateGdbJob = gdbTask.GenerateGeodatabase(gdbParams, localGeodatabasePath);
            // Handle the job changed event and check the status of the job; store the geodatabase when it's ready.
            generateGdbJob.StatusChanged += (s, e) =>
                // See if the job succeeded.
                if (generateGdbJob.Status == JobStatus.Succeeded)
                    DispatcherQueue.TryEnqueue(Microsoft.UI.Dispatching.DispatcherQueuePriority.Normal, () =>
                        // Hide the progress control and update the message.
                        MessageTextBlock.Text = "Created local geodatabase";
                else if (generateGdbJob.Status == JobStatus.Failed)
                        // Hide the progress control and report the exception.
                        MessageTextBlock.Text = "Unable to create local geodatabase: " + generateGdbJob.Error.Message;
            // Start the generate geodatabase job.
            _localGeodatabase = await generateGdbJob.GetResultAsync();
    catch (Exception ex)
        // Show a message for the exception encountered.
            _ = new MessageDialog2("Unable to create offline database: " + ex.Message).ShowAsync();
Strangely enough it seems to loaded the Domains , so I know its downloaded the correct table:
Editing is enabled in the service, and all users should be able to view features:
JoeHershman
Are you calling LoadAsync ?
You need to explicitly Load tables/layers, etc
-Joe
MoyerSolutions
So I have tried to make a smaller test case using ServiceFeatureTable or through ServiceGeodatabase:. Results are same: empty table
public static async Task ServiceGeodatabase() {
    var serviceGeodatabase = new ServiceGeodatabase(new Uri(featureServiceUri));
    await serviceGeodatabase.LoadAsync();
    ServiceFeatureTable table = serviceGeodatabase.GetTable(0);
    _ = table.Fields; //breakpoint here, why this is empty?
-or-
public static async Task GetServiceTable() {
    ServiceFeatureTable table = new(new Uri(featureServiceUri));
    var layer = new FeatureLayer(table);
JoeHershman
-Joe
MoyerSolutions
That was it. Thank you!
MoyerSolutions
Follow up question, not sure if I should make a new topic, but now I am trying to read the fields / attributes from the table after it has been loaded. I keep getting "null" as a response. There is data in the table. Is there something else I need to call to load the actual values themselves?
edit: solved
