Object is already owned, C#
202
a week ago
Labels (2)
SP2501
Running into 2 related issues
I have a map the users interact with, it uses an Operational Layer and a graphics overlay collection
Now my issue
If the user closes the map, and then comes back into the map, I run into this error.
For Graphics overlays I have been trying to clear() both the graphics layer on the map and clear() the graphics collection
EsriMapView.GraphicsOverlays.Clear();
BasicOverlays.Clear();  GraphicCollection
We do A WHOLE lot of stuff, and then I bomb here.
EsriMapView.GraphicsOverlays = BasicOverlays;// this is bombing on re enter
The operational layer is a little more tricky, and does NOT bomb whenever I come back in. But wont allow me to change the data or redraw the data, like if the user selects a different file to load, or changes a rendering option.
//Are we entering this again?
if (SectorLayer != null)  Not firing on reenter, but does if I try and call this method again to "redraw"
EsriMapView.Map.OperationalLayers.Remove(SectorLayer);
SectorLayer = null;
try
SectorLayer = new Esri.ArcGISRuntime.Mapping.FeatureLayer(BlockGroupGeoPackage.GeoPackageFeatureTables[0]); <- Bombs here
catch
MessageBox.Show("Error Adding Sector Outlines");
SectorLayer.Renderer = _alternateRenderer;
EsriMapView.Map.OperationalLayers.Add(SectorLayer);
Both are showing the same error, could someone help me out here understanding this? According the debug the layers are clear, the SectorLayer is Null, the graphics layers & collection are clear, and the map.operational layer is clear.
GKmieliauskas
You have situation similar like in thread. I think BlockGroupGeoPackage.GeoPackageFeatureTables[0] makes a bomb. You need to create object from scratch, because Maps SDK saves somewhere your used objects.
GKmieliauskas
SP2501
GK, thanks for the input! Thread helped.
dotMorten_esri
Esri Notable Contributor
A Map or a GraphicsOverlay can only be attached to a single MapView instance. So when you reuse those objects, make sure they are unhooked from the old mapview.
Now this gets a little tricky because of the garbage collector meaning you don't really know when the MapView is getting collected and unhooked from the map and graphics collection. A couple approaches you can do to make that more deterministic:
1. Either reuse the same MapView across pages
2. When navigating away from the mapview page, set the Map and GraphicsOverlays properties to null to unhook them immediately and get them unowned.
