Local Server ARM
1137
03-18-2023 07:46 AM
Labels (3)
seanlwl
I wonder whether ArcGIS Runtime SDK for .Net Local Server component is supported on Windows 11 ARM-based PCs, such as Surface Pro X。
MichaelBranscomb
Esri Frequent Contributor
Do you have a device and you've tried this, or you're enquiring if it will work before purchasing the device?
AzinSharaf
@seanlwl  have you figured it out?
i don't know the answer but i used ArcGIS Pro on Win 11 Arm based (virtual Machine) for a while and everything was fine. Recently (probably after 3.0.1 upgrade) it stoped working and arcpy crashes if we install MS Visual C ++ Redist (I have tried both 64x and ARM and ArCGIS Pro crashed with both)
MichaelBranscomb
It sounds like you're referring to Windows running as a guest OS on a Mac computer via Parallels? As opposed to Windows on ARM on a device such as one of the ARM-based Surface devices or from a developer perspective the new Windows Dev Kit?
AzinSharaf
a Win 11 Pro guest on a Macbook M1 Max via Parallels Pro 18.2.
