Is there anyway to change selected "halo" for all layers
776
07-16-2024 03:18 AM
Labels (4)
ofirrosner
Im using esri 100.15 / 200.4 (two different projects)
And i want to change the color and the with of the "halo" when selecting some graphic
To change the color i found SelectionProperties , but i only have a color property (both in 100.15 and 200.4)
I don't want to create a composite symbol for every layer and create a logic accordingly
is there a way to make some generic code, or is there any property that i've missed
dotMorten_esri
Esri Notable Contributor
At this point, only the selection halo color is settable as you've discovered.
ofirrosner
is there a way in-code i can achieve my goal?
dotMorten_esri
Apart from overriding the symbol or rendering a second symbol in a graphic overlay to highlight it, I can't think of any no.
ofirrosner
how can i override my symbol to add an halo
if i create a multi symbol layer, the 2 layers are on top of each other and not "on the side" normal regular selection
