Is the identify function not possible in the version 100
3051
03-30-2017 09:31 AM
Pierre-JeanMuller
I tried to do an identify
var task = MainMapView.IdentifyLayerAsync(srtmValueLayer, e.GetPosition(MainMapView), 0,false ,1);
I get this error in the task result of the task :
Error = {"Invalid argument: Identify parameters do not specify a region in the view extent."}
According to the list that shows the implemented functionalities in the version 100:
Choosing the right version | ArcGIS for Developers
The ImageServiceLayer is not implemented. So do I have to change to the version 10.2.7 in order to have an identify function?
JenniferNery
This should work in v100. What event are you using and what's e.GetPosition(MainMapView)'s value when you get this error?
var position = e.GetPosition(MainMapView);
System.Diagnostics.Debug.WriteLine(position.ToString());
You can also try the following code. Using GeoViewTapped, you can pass either specific layer or identify all layers. In the identified result, notice that ArcGISMapImageLayer have results in SublayerResults and FeatureLayer have results in GeoElements.
        xmlns:esri="http://schemas.esri.com/arcgis/runtime/2013">
    <Grid>
        <esri:MapView x:Name="MyMapView" GeoViewTapped="MyMapView_GeoViewTapped">
            <esri:Map>
                <esri:ArcGISMapImageLayer Source="http://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer" />
                <esri:FeatureLayer>
                    <esri:ServiceFeatureTable Source="http://sampleserver6.arcgisonline.com/arcgis/rest/services/Notes/FeatureServer/0" />
                </esri:FeatureLayer>
            </esri:Map>
        </esri:MapView>
    </Grid>‍‍‍‍‍‍‍‍‍‍‍
        private async void MyMapView_GeoViewTapped(object sender, GeoViewInputEventArgs e)
            try
                Layer layer = null;
                layer = MyMapView.Map.AllLayers.OfType<ArcGISMapImageLayer>().FirstOrDefault();
                var identifyResult = await MyMapView.IdentifyLayerAsync(layer, e.Position, 1, false, 1);
                DisplayResult(identifyResult); // results in SublayerResults
                layer = MyMapView.Map.AllLayers.OfType<FeatureLayer>().FirstOrDefault();
                DisplayResult(identifyResult); // results in GeoElements
                var identifyResults = await MyMapView.IdentifyLayersAsync(e.Position, 1, false, 1);
                foreach (var result in identifyResults)
                    DisplayResult(result);
            catch (Exception ex)
                MessageBox.Show(ex.Message);
        private string GetGeoElements(IEnumerable<GeoElement> geoElements)
            var sb = new StringBuilder();
            foreach (var g in geoElements)
                foreach (var a in g.Attributes)
                    sb.AppendLine($"{a.Key}={a.Value}");
            return sb.ToString();
        private string GetSublayerResult(IEnumerable<IdentifyLayerResult> sublayerResults)
            foreach (var r in sublayerResults)
                sb.AppendLine($"{r.LayerContent.Name} has {r.GeoElements.Count} results");
                var summary = GetGeoElements(r.GeoElements);
                if (!string.IsNullOrEmpty(summary))
                    sb.AppendLine(summary);
        private void DisplayResult(IdentifyLayerResult result)
            var summary = GetGeoElements(result.GeoElements);
            summary = GetSublayerResult(result.SublayerResults);
            summary = sb.ToString();
            if(!string.IsNullOrEmpty(summary))
                MessageBox.Show(summary);
JenniferNery
    <Grid>
            <esri:Map>
                <esri:FeatureLayer>
            </esri:Map>
        </esri:MapView>
    </Grid>‍‍‍‍‍‍‍‍‍‍‍
            try
                Layer layer = null;
Pierre-JeanMuller
Thanks for the answer, my problem was the way I used to show the results
Pierre-JeanMuller
But what I found a little bit strange, that I can't identify a layer without being added to the mapView and if I put the visibility or the opacity to zero, I get no results.
brysageek
I am not entirely sure about the design decision around not continuing the IdentifyTask, there are many use cases where we would want to query services that aren't added to our map, I do see that there are benefits to having us go through GeoView--will the identifyTasks be brought back down to the individual service level?
