Internal error opening MobileMapPackage with UNC path
1510
08-02-2018 10:48 AM
WillMebane
I am attempting to load a mobile map package from a UNC path (), but getting the following exception:
Esri.ArcGISRuntime.ArcGISRuntimeException: 'Internal error'
I am loading the map package with the following line:
MobileMapPackage sourceMapPackage = await MobileMapPackage.OpenAsync("\\computer_name\Share\OperationalLayers\OperationalLayers.mmpk");
I don't have any issues if I use a path to a folder in my local machine, or if I map the network location to a local drive.  Are UNC paths supported, and if so, is this a bug or should I be loading it differently?  This is with Runtime 100.1
MichaelBranscomb
Esri Frequent Contributor
Are you able to reproduce with v100.3?
Cheers
Mike
dotMorten_esri
Esri Notable Contributor
Are you using WPF? (this wouldn't work in UWP)
