I couldn't fully figure out GeoprocessingTask and the Elevation Profile. Help me understand why outputFeatures.CanGetOutputFeatures is always false? My code:
var _elevationServiceUrl = new Uri("https://elevation.arcgis.com/arcgis/rest/services/Tools/ElevationSync/GPServer/Profile");
var geoprocessingTask = await GeoprocessingTask.CreateAsync(_elevationServiceUrl);
var fields = new List<Field>
var featureTable = new FeatureCollectionTable(fields, GeometryType.Polyline, SpatialReferences.Wgs84);
var feature = featureTable.CreateFeature();
feature.Geometry = polyline;
await featureTable.AddFeatureAsync(feature);
var parameters = await geoprocessingTask.CreateDefaultParametersAsync();
parameters.Inputs["InputLineFeatures"] = new GeoprocessingFeatures(featureTable);
parameters.Inputs["DEMResolution"] = new GeoprocessingString("FINEST");
parameters.Inputs["MaximumSampleDistance"] = new GeoprocessingDouble(200);
parameters.ReturnM = true;
parameters.ReturnZ = true;
var job = geoprocessingTask.CreateJob(parameters);
var result = await job.GetResultAsync();
if (result.Outputs.ContainsKey("OutputProfile"))
var outputFeatures = result.Outputs["OutputProfile"] as GeoprocessingFeatures;
if (outputFeatures != null && outputFeatures.CanGetOutputFeatures)
var featureSet = await outputFeatures.GetOutputFeaturesAsync();
foreach (var outputFeature in featureSet)
var geometry = outputFeature.Geometry as Polyline;
// Подальша обробка геометрії
else
MessageBox.Show("Помилка: OutputProfile не містить даних або не підтримує отримання результатів.");
As I understand from API reference, it must be like that:
IFeatureSet featureSet;
if (outputFeatures.CanGetOutputFeatures)
else
featureSet = outputFeatures.Features ;
else
I really appreciate your response.This check should work
My final code:
public async Task<List<MapPoint>?> GetElevationProfile(Polyline polyline)
List<MapPoint> resultPoints = new();
var featureTable = new FeatureCollectionTable(new List<Field>(), GeometryType.Polyline, polyline.SpatialReference);
parameters.Inputs.Add("InputLineFeatures", new GeoprocessingFeatures(featureTable));
parameters.Inputs.Add("DEMResolution", new GeoprocessingString("FINEST"));
parameters.Inputs.Add("MaximumSampleDistance", new GeoprocessingDouble(200));
parameters.OutputSpatialReference = SpatialReferences.Wgs84;
parameters.ReturnM = false;
try
if (result?.Outputs?.ContainsKey("OutputProfile") == true)
if (outputFeatures != null)
IFeatureSet? featureSet = outputFeatures!.CanGetOutputFeatures ? await outputFeatures!.GetOutputFeaturesAsync() : outputFeatures!.Features;
if (featureSet != null)
if (outputFeature?.Geometry?.GeometryType == GeometryType.Polyline)
var poly = outputFeature.Geometry as Polyline;
var points = poly?.Parts.SelectMany(x => x.Points);
if (points != null) resultPoints.AddRange(points);
return resultPoints;
else MessageBox.Show("Помилка: OutputProfile не містить даних або не підтримує отримання результатів.");
else MessageBox.Show("Помилка: GetResultAsync не містить даних");
catch
return null;
