How to View Table of Contents in version 100.2.1 ??
2677
10
03-23-2018 04:17 AM
VijitWadhwa
I am trying to explore , Table of Contents of layers . How can i do that in version 100.2.1  ??
MichaelBranscomb
Esri Frequent Contributor
You can find a Table of Contents implementation in the Toolkit. That's the link for the source code.
The Toolkit components are currently in beta - you can get a NuGet package for the latest master build by adding the URL `https://ci.appveyor.com/nuget/arcgis-toolkit-dotnet` as a NuGet feed in the Visual Studio Package Manager. For more info see Setting up Local NuGet Feeds | Microsoft Docs.
Cheers
Mike
VijitWadhwa
Thanks for the help sir, But how can I view table of contents on a offline map??
VeronicaValenzuela
I am also wondering this.
VijitWadhwa
Which version are you using ?
VijitWadhwa
If You are using version 100.4, then you need to add two nuget packages ArcGISRuntime Toolkit 100.4 and ArcGIS Runtime Toolkit Preview 100.4 . TableOfContents class is available in ArcGISRuntime Toolkit Preview Nuget Package.
Hope I could help
VeronicaValenzuela
Yes I am, but when I search for Nuget packages inside Visual Studio, I don't see anything related to a Toolkit. Am I looking in the wrong place?
VijitWadhwa
Select Nuget instead of all . . And then go in browse option and then
search , u will find it easily . .
Hope I could help
VeronicaValenzuela
For some reason, my Visual Studio doesn't list Nuget as a source. My only available sources are Esri and Visual Studio Offline Packages.
VeronicaValenzuela
I got it to work. I just downloaded the package itself from the nuget website and put that in my esri nuget folder. Thanks!
