How to tell when GeoprocessingJob has been canceled?
1732
06-15-2020 01:03 PM
by Anonymous User
Not applicable
I don't see a JobCanceled in the JobStatus enumeration.
When I call Cancel on a GpJob, the next status update status says failed.
Is there some way to verify that it's been canceled - and not failed?
BTW, the REST API Jobstatus has "esriJobCanceled" along with some others that aren't in the .NET SDK...
  • esriJobSubmitted (missing)
  • esriJobWaiting (paused?)
  • esriJobExecuting (started?)
  • esriJobSucceeded
  • esriJobFailed
  • esriJobTimedOut (missing)
  • esriJobCancelling (missing)
  • esriJobCancelled (missing)
MichaelBranscomb
Esri Frequent Contributor
Kirk,
The `Job` in this case represents a Runtime Job which handles specific runs of the Task instance. It's a common framework for Runtime Tasks. For Geoprocessing the Job can be either:
- Synchronous "execute"
- Asynchronous "submit job"
Only the server-side "submit job" type provides a job ID and the status list you shared above. Those status values will be available in the Messages property of the GeoprocessingJob class.
Thanks
Mike
MichaelBranscomb
Kirk,
Thanks
Mike
by Anonymous User
Not applicable
Hi Michael -
This seems to work with the LocalServer geoprocessing sample.  Glad to see ArcGIS Enterprise returns the same "Job canceled" too.
Thanks!
EricBader2
Hey Mike,
If I cancel a sync process, does this Cancel actually 'roll back' anything that took place during the job process before the cancel? I was assuming it does.
Thanks!
