How to implement RubberBand ZoomIn??
1461
04-16-2018 05:38 AM
VijitWadhwa
How can i zoomin to a map , by drawing a rectangle on the map and zoom that particular area?? Please Help Michael BranscombAntti KajanusMorten Nielsen@
Thanks in advance,
Vijit
AnttiKajanus1
By default, you can hold "Shift" key and then draw a rectangle on the MapView to use similar navigation. If you want to zoom out, you can do "Shift+ Ctrl" combo instead.
If you want to implement your own, then you can do something like this:
 private async void Button_Click(object sender, RoutedEventArgs e)
            try
                // use the MapView's Editor to request geometry (Envelope) from the user and await the result
                var newExtent = await myMapView.SketchEditor.StartAsync(Esri.ArcGISRuntime.UI.SketchCreationMode.Rectangle, false);
                // set the map view extent with the Envelope
                await myMapView.SetViewpointGeometryAsync(newExtent);
            catch (TaskCanceledException tce)
                // sketching cancelled
            catch (Exception ex)
VijitWadhwa
Thankyou Sir.
