How to create a new FeatureService PortalItem
954
10-31-2019 09:17 AM
EugenD
What is the correct way to create a new PortalItem of type FeatureService?
I am logged in with a Publisher account and have tried following methods:
var portalItem = new PortalItem( portal, PortalItemType.FeatureService, "NewFeatureService");
await portal.User.AddPortalItemAsync(portalItem);
I get the exception:
Esri.ArcGISRuntime.Http.ArcGISWebException: ''url' parameter is required for this type.'
Where should i define the url parameter?
Also I have followed other example from the community and create a portal item based on a feature collection.
var featureLayerUrl = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire/FeatureServer/0";
// Create a service feature table to get features from
 var serviceFeatureTable = new ServiceFeatureTable(new Uri(featureLayerUrl));
// Create a query to get all features in the table
QueryParameters queryParams = new QueryParameters {WhereClause = "1=1"};
// Query the table to get all features
var featureQueryResult = await serviceFeatureTable.QueryFeaturesAsync(queryParams);
// Create a new feature collection table from the result features
var featureCollectionTable = new FeatureCollectionTable(featureQueryResult)
      Renderer = new SimpleRenderer(new SimpleMarkerSymbol(SimpleMarkerSymbolStyle.Circle, Color.Red, 8)),
      DisplayName = "Table Name"
// Create a feature collection and add the table
var featureCollection = new FeatureCollection();
featureCollection.Tables.Add(featureCollectionTable);
await featureCollection.LoadAsync();
var tags = new List<string> {"Save Feature collection"};
await featureCollection.SaveAsAsync(portal, null, "Feature Collection to PortalItem", "FeatureCollection", tags);
In this case i can see the new FeatureLayer in my ArcGIS Online content page. I can see the geometry and the data in the map viewer.
But in this case the layer name on the details page is set as "Undefined", and when i publish it (with the ArcGIS web interface) the new created FeatureLayer (hosted) is empty.
Is there a way to publish the portal item similar to the rest api?
Any help would be greatly appreciated
dotMorten_esri
Esri Notable Contributor
Creating layer portal items from the Runtime aren't supported at this point (I believe only Maps are supported at this point via the Map.SaveAs method).
