How to clone a KmlLayer including loaded KmlDataSet?
935
07-10-2023 07:01 AM
Labels (3)
SokoFromNZ
I've implemented myself a global/static KmlLayer cache () as loading its data from the web can take a long time.
When I add the instance from the cache to a MapView
MapView1.Map!.OperationalLayers(_staticCache.First(k => k.Dataset?.Source == uri);
all is fine.
But if I do this to a second time:
MapView2.Map!.OperationalLayers(_staticCache.First(k => k.Dataset?.Source == uri);
I get an "Object already owned" exception.
So far so good...I thought...then I just clone the already loaded instance of the cache before I add it to the MapViews...
MapView1.Map!.OperationalLayers((_staticCache.First(k => k.Dataset?.Source == uri).Clone());
MapView2.Map!.OperationalLayers((_staticCache.First(k => k.Dataset?.Source == uri).Clone());
But the clones status (of the Dataset) is `NotLoaded` and the data is downloaded again from the web!
Why is the loaded data not cloned? I haven't found any way to clone/copy or use KmlData once loaded from the web multiple times. How do I do that?
Soko
SokoFromNZ
Can nobody give me a hint here? Its really a bad thing to download the same data multiple times just to show them in different maps!
