Graphic Point Does Not Display
3057
12-15-2015 04:03 PM
GreggCountryman1
Hello,
I have a simple map containing a Tiled Layer, and a cashed layer. When I add a Graphic Point, it will only display if I do not load the Tiled Service.
Here is the code:
                var streetsCacheLayer = new ArcGISTiledMapServiceLayer(new Uri(streetsCacheUrl));
                streetsCacheLayer.MaxScale = 36111;
                var streetsDynamicLayer = new ArcGISDynamicMapServiceLayer(new Uri(streetsDynamicUrl));
                var graphicsLayer = new Esri.ArcGISRuntime.Layers.GraphicsLayer();
                graphicsLayer.ID = "MyGraphics";
                var mapPoint = new MapPoint(-76.644759, 39.516597);
                var depotSym = new SimpleMarkerSymbol { Style = SimpleMarkerStyle.Circle, Size = 16, Color = Colors.Green };
                var depotMapGraphic = new Graphic { Geometry = mapPoint, Symbol = depotSym };
                graphicsLayer.Graphics.Add(depotMapGraphic);
                 await streetsCacheLayer.InitializeAsync();
                await streetsDynamicLayer.InitializeAsync();
                await graphicsLayer.InitializeAsync();
                // If I comment out the next line the graphic shows up, otherwise it does not.
                MyMap.Layers.Add(streetsCacheLayer);
                MyMap.Layers.Add(streetsDynamicLayer);
                MyMap.Layers.Add(graphicsLayer);
Any ideas?
Ed
AnttiKajanus1
My guess is that the tile layer is in different SpatialReference. Can you make sure that you use the same SR for the graphic too.
