Geometry type does not match the geometry field.
3903
05-31-2016 04:48 PM
SaurabhGupta1
I have created .geodatbase using the ArcGIS Runtime content ( Ver 10.2.1) but when I am trying to add this for offline method this is giving me "Geometry type does not match the geometry field." error.
var gdb3 = await Esri.ArcGISRuntime.Data.Geodatabase.OpenAsync(@".geodatabase");
                foreach (var table in gdb3.FeatureTables.ToList())
                    // create a new feature layer to display each table
                    var lyr = new FeatureLayer
                        ID = table.Name + "Offline3",
                        DisplayName = table.Name,
                        FeatureTable = table
                    // add each layer to the map
                    MyMapView.Map.Layers.Add(lyr);
Tags (1)
YuanLiu
Hi, did you miss any code when pasting it here? Seems like the lyr object is still a new feature layer, and nothing has been assigned to it before added to the map.
SaurabhGupta1
Hi Yuan,
nothing is missing in code. This is giving error when open the geodatabase at very first line
"var gdb3 = await Esri.ArcGISRuntime.Data.Geodatabase.OpenAsync(@".geodatabase");"
and assigned the below properties when create the FeatureLayer.
YuanLiu
Oops, my bad. I see it now
