FeatureLayer.SelectFeature() - Polygon fill symbol (Colorize the area of a polygon)
3803
01-21-2016 11:49 AM
OliverBrandt2
Hi all,
how can I fill the whole polygone after selecting it on a featureLayer? FeatureLayer supports only to highlight the lines of the polygon by default. In ArcMap it is possible to set a selection symbol, which allows to color the included area.
Do anybody have an idea to solve this?
Thank you guys!
AnttiKajanus1
Hi Oliver,
I think that you need to copy the feature as a graphic to GraphicsOverlay and define your custom selection symbol as a symbol for that one. Also you might want to hide the selected feature from the FeatureLayer using featureLayer.SetVisibility method. There is a bit more code involved with this approach but it gives you full control what is shown with what symbols and when.
AnttiKajanus1
Hi Oliver,
OliverBrandt2
Hi Antti,
thanks for your response. Taking the geometry and creating a graphic out of it, is an good approach. I'll try this.
by Anonymous User
Not applicable
Hi Oliver,
The following VBA sample is able to set the selection symbol to be solid green:
Public Sub SetSeleSymbol()
    Dim pMxDoc As IMxDocument
    Set pMxDoc = ThisDocument
    Dim pMap As IMap
    Set pMap = pMxDoc.FocusMap
    Dim pFeatLayer As IFeatureLayer
    Set pFeatLayer = pMap.Layer(0)
    Dim featSel As IFeatureSelection
    Set featSel = pFeatLayer
    Dim polySym As ISimpleFillSymbol
    Set polySym = New SimpleFillSymbol
    Dim pColor1 As IRgbColor
    Set pColor1 = New RgbColor
    pColor1.Red = 0
    pColor1.Green = 250
    pColor1.Blue = 0
    Dim pcolor2 As IRgbColor
    Set pcolor2 = New RgbColor
    pcolor2.Red = 0
    pcolor2.Green = 0
    pcolor2.Blue = 250
    Dim pLineSym As ILineSymbol
    Set pLineSym = New SimpleLineSymbol
    pLineSym.Color = pcolor2
    pLineSym.Width = 2
    polySym.Color = pColor1
    polySym.Outline = pLineSym
    featSel.SetSelectionSymbol = True
    Set featSel.SelectionSymbol = polySym
End Sub
Results will be like this:
OliverBrandt2
Thank you! This is an very interesting example, but we are using ArcGIS runtime for .NET.
I worked with Antti's approach.
My Code is:
var color = Color.FromArgb(150,140,235,240);
var selectionColor = new SimpleFillSymbol
                Color = color
var selectedPolygon = GeodatabaseFeature.AsGraphic();
selectedPolygon.Symbol = selectionColor;
_MapView.GraphicsOverlays[PolygonGraphicsOverlayKey].Graphics.Add(selectedPolygon);
At my clearSelection method I clear the PolygonGraphicsOverlay as well. This works very good for me.
