Excute ServiceFeatureTable.QueryFeatureAsync Catch Exception
4189
8
08-21-2017 06:00 AM
xiaoguangyan
Hi, when I excute the below codes, somethimes it will catch the "Invalid URI: URI string too long" exception.
QueryParameters queryParams = new QueryParameters()
WhereClause="name like '%"+ (stateName.ToUpper()) + "%'",
Geometry=searchGeometry
// Query the feature table
FeatureQueryResult queryResult = await _featureTable.QueryFeaturesAsync(queryParams);
I don't konw this is because there is something wrong with my input geometry or some else?
Tags (1)
dotMorten_esri
Esri Notable Contributor
In order to reproduce, what's the 'stateName' value, and could you share the Geometry as Json? (searchGeometry.ToJson())
Also which version of the ArcGIS Runtime are you using?
xiaoguangyan
Hi, sorry, actually I want to query a point ServiceFeatureTable within a polygon geometry, my codes like below, Geometry Jsons are attached
var queryParameters = new QueryParameters
Geometry = bufferGeometry,
SpatialRelationship = SpatialRelationship.Intersects,
//MaxFeatures = 50
FeatureQueryResult queryResult = await _featureTable.QueryFeaturesAsync(queryParameters);
xiaoguangyan
I am using the ArcGIS Runtime 100.1
RussellSchwab
Has there been any resolution for this?  I have the same problem with Runtime 100.2.  I'm sure it has to do with the complexity of the query geometry - the query runs fine with a simple geometry, but I get the "URI string too long" error with a complex geometry.
SalieghAziz
Morten Nielsen‌ I am having the same issue. In Runtime 10.2.x, if my map service has a limit of 1,000 features, that 1k will be returned, but when it has a max return record count of 50k, I get back zero results.
I now decided to test against 100.4, and I get the same exception mentioned above. The size of the shape does not seem to be the problem. My original shape has 900+ rings and this fails. When I attempt an overlap with the extent of this complex shape, I get back results the 50k max.
I am happy to share the service I am testing against, as well as the geometry in question, but this will need to be in a private forum due to it being sensitive data.
xiaoguangyan
Hi, Saliegh,
 Yes, I remember that if the input geometry has too much rings it would get exception
SalieghAziz
Hi xiaoguang yan
How did you resolve the issue?
xiaoguangyan
Hi  Saliegh,
 I  created a custom gp tool to solve this
