EncExchangeSet.LoadAsync() Internal Error: Failed to load ENC exchange set
1658
04-08-2022 01:59 AM
irseadam
When I try to load an EncExchangeSet object, I get the following error:
Esri.ArcGISRuntime.ArcGISRuntimeException: Internal Error: Failed to load ENC exchange set
I use the same code provided in the sample codes section (https://developers.arcgis.com/net/wpf/sample-code/add-enc-exchange-set/), and I feed the EncExchangeSet constructor with a valid path to a "CATALOG.031" file.
I get this error in the loading step:
await myEncExchangeSet.LoadAsync();
What may cause this error and what should I do to fix this?
HydroExpert
Hello, are you able to share the CATALOG.031 file?
Can you paste the code that loads the CATALOG.031 file?
hesapadam
I am trying the file attached below.
And I am using the code from this example: https://developers.arcgis.com/net/wpf/sample-code/add-enc-exchange-set/
In the
line, I get this error:
HydroExpert
These charts are Inland ENC (IENC) and apparently not supported by ArcGIS Runtime.
I was able to view them with an older version (100.2).
Use this demo app: https://github.com/Esri/arcgis-runtime-demos-dotnet/tree/main/src/HydrographicsSample
HydroExpert_0-1650639779592.pngHydroExpert_1-1650639836410.pngHydroExpert_2-1650639894705.png
However, ArcGIS Runtime versions after 100.2 will not load IENC data.
