DRAWING ARCS
3488
8
08-03-2022 02:47 AM
FranciscoLopez
Hi everyone.
I need to draw several arcs in a overlay. I need to make a function where with a location, angle and distance, draw an arc like the attached file.
ThadTilton
Here's the function:
private Geometry CreateDensifiedWedgeGeometry(MapPoint center, double radius, double arcAngle, double azimuth)
    SpatialReference spatialReference = center.SpatialReference;
    // Get the angle of the azimuth.
    var directionAngle = 90 - azimuth;
    directionAngle = (directionAngle < 0) ? directionAngle + 360 : directionAngle;
    directionAngle = (directionAngle > 360) ? directionAngle - 360 : directionAngle;
    // Subtract half of the arc angle from the direction (wedge should be split by the azimuth angle).
    var startPointDegrees = directionAngle - (arcAngle / 2);
    startPointDegrees = (startPointDegrees < 0) ? startPointDegrees + 360 : startPointDegrees;
    startPointDegrees = (startPointDegrees > 360) ? startPointDegrees - 360 : startPointDegrees;
    // Get the radian values of the angles.
    var startPointRadians = startPointDegrees * Math.PI / 180.0;
    var arcAngleRadians = arcAngle * Math.PI / 180;
    // Create an arc segment with the center point, radius, start point of the arc, arc angle, and spatial reference.
    EllipticArcSegment arc = EllipticArcSegment.CreateCircularEllipticArc(center, radius, startPointRadians, arcAngleRadians, spatialReference);
    // create the sides of the wedge (center point to start/end points of the arc).
    var startSide = new LineSegment(center, arc.StartPoint);
    //var endSide = new LineSegment(center, arc.EndPoint);
    // Create the wedge-shaped polygon.
    PolygonBuilder builder = new PolygonBuilder(spatialReference);
    // Note: only need to add one of the sides to complete the polygon.
    builder.AddPart(
        new Part(new Segment[]
           startSide,
           arc
        }, spatialReference)
    // Densify the arc for display in 3D.
    var densifiedPoly = GeometryEngine.Densify(builder.ToGeometry(), 100000);
    return densifiedPoly; // builder.ToGeometry();
I call it with this:
private void CreateWedgeButton_Click(object sender, RoutedEventArgs e)
    MapPoint origin = new MapPoint(x: 40e5, y: 5e5, SpatialReferences.WebMercator);
    Geometry wedgeGeometry = CreateDensifiedWedgeGeometry(origin, 1000000, 90, 360);
    Graphic wedgeGraphic = new Graphic(wedgeGeometry);
    var curvedGraphicsOverlay = MySceneView.GraphicsOverlays["curvedoverlay"];
    curvedGraphicsOverlay.Graphics.Add(wedgeGraphic);
    MySceneView.SetViewpoint(new Viewpoint(wedgeGeometry));
ThadTilton
This seems to work, perhaps give it a test to make sure you get the correct shape based on your inputs.
private Geometry CreateWedgeGeometry(MapPoint center, double radius, double arcAngle, double azimuth)
    builder.AddPart(
            startSide,
            arc
    return builder.ToGeometry();
 Based on your image, "arcAngle" is α, and "radius" is D. The "azimuth" defines the orientation (compass direction) of the wedge. To create something like what's shown in your image, you'd call it like this:
Geometry wedge = CreateWedgeGeometry(originPoint, 1000000, 90.0, 360.0);
 Hope that helps, Thad
FranciscoLopez
Hi, first of all, thanks a lot for your help. I have used your code to make this:
MapView.CreateAimingZone(_latitude, _longitude, 0.078,90,180);
public void CreateAimingZone(double latitude, double longitude, double radius, double arcAngle, double azimuth)
MapPoint center = new MapPoint(longitude,latitude);
Graphic AimiinZone = CreateWedgeGeometry(center, radius, arcAngle, azimuth);
_ringRange_GO.Graphics.Add(AimiinZone);
private Graphic CreateWedgeGeometry(MapPoint center, double radius, double arcAngle, double azimuth)
builder.AddPart(
startSide,
arc
Graphic ellipseGraphic = new Graphic(builder.ToGeometry());
//return builder.ToGeometry();
return ellipseGraphic;
My result is in the attached file, I am doing something wrong. I have made a tringle.
Other different is a use de value 1000000 in radius I can't see anything, but i I use 0.08 the Radius, Distance is 8Km.
FranciscoLopez
I forget I and using SceneView not MapView. I want to draw it in SceneView . Do you know how?
FranciscoLopez
Hi ThadTilton
Please, see the link EllipticArcSegment.CreateCircularEllipticArc To see what is the problem with EllipticArcSegment.CreateCircularEllipticArc
Anyway, Thanks a lot for your help. I have learned a lot.
Regards
ThadTilton
Hey Francisco, for display in 3D, you need to densify the arc. This will represent the arc as a series of linear segments rather than a true curve. The tricky part might be finding the ideal "maxSegmentLength" to get a smooth curve (without going too small, which could hurt performance). Here's an example of densifying so the returned "curve" is composed of segments not less than 10,000 meters (10 km).
var densifiedPoly = GeometryEngine.Densify(builder.ToGeometry(), 10000);
FranciscoLopez
I am sorry  ThadTilton, I can't get your result. Please could you send me the code to get the result you attached?
ThadTilton
    builder.AddPart(
           startSide,
           arc
FranciscoLopez
Thanks a lot. My problem is than I am new in GIS and I have problem to understand the concepts. I have to learn about the different Dantum. Any way, thanks a lot for your solution.
