ERROR 000814: Invalid file type Failed to Execute (JSONToFeature) when run on Local Server
2365
08-13-2022 02:32 PM
noodle
Failed to execute. Parameters are not valid. ERROR 000814: Invalid file type Failed to execute (JSONToFeatures).    I cannot figure out why the file is "Invalid file type".   It is a json serialized (type is "Feature Layer" and geometryType is "esriGeometryPolygon").   I can run the script under ArcGIS Pro 2.94 and 3.0 successfully.
Traceback (most recent call last): File "<string>", line 48, in main File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\conversion.py", line 1169, in JSONToFeatures raise e File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\conversion.py", line 1166, in JSONToFeatures retval = convertArcObjectToPythonObject(gp.JSONToFeatures_conversion(*gp_fixargs((in_json_file, out_features, geometry_type), True))) File "C:\Program Files\ArcGIS SDKs\LocalServer100.14\64\Pro\Resources\ArcPy\arcpy\geoprocessing\_base.py", line 512, in <lambda> return lambda *args: val(*gp_fixargs(args, True)) arcgisscripting.ExecuteError: Failed to execute. Parameters are not valid. ERROR 000814: Invalid file type Failed to execute (JSONToFeatures). During handling of the above exception, another exception occurred: Traceback (most recent call last): File "<string>", line 75, in <module> File "<string>", line 51, in main File "C:\AEDT\Temp\NETLOC~1\Documents\ArcGIS\Pkgs\jsontofeature_6393\p20\jsontofeature\aedt.py", line 101, in handleExceptions arcpy.AddError(e.message) AttributeError: 'ExecuteError' object has no attribute 'message'
noodle
Problem solved.   LocalServer100.14 does not support JSON serialized type being "Feature Layer".   When I changed the type to "JsonFeatures", it worked.   Backward compatibility is broken in LocalServer100.14.
MichaelBranscomb
Esri Frequent Contributor
Glad you found the solution to your problem.
But I'm curious what file type / content you're using as input - Is it GeoJson?
