Documentation For Migrating From ArcGIS Engine
1216
03-29-2022 06:23 AM
adamgibi
Is there any documentation available for migrating from ArcGIS Engine to ArcGIS Runtime in terms of code? I am aware of the existence of "ArcGIS Runtime: Migrating from ArcGIS Engine" videos but they do not provide code examples and I need some coding documentation, for example which classes in Runtime correspond to the classes in Engine, etc. Any help is appreciated, thanks in advance.
dotMorten_esri
Esri Notable Contributor
Engine and Runtime are two vastly different architectures, so a one-to-one mapping of classes is going to be really tough /  impossible. Also you might be looking at changing the approach or workflows to solve certain use-cases. I'd recommend you install the WPF Sample Viewer (https://www.microsoft.com/store/productId/9MTP5013343H) and find samples that shows how to do various workflows you're looking to duplicate and study the code behind each sample.
