Dockpane with listed files: drag&drop method to add files to map does not work. where's the issue?
1249
09-06-2023 11:31 PM
nadja
Hi - I'm new to this SDK and C#. I'm trying to code a dockpane which lists all rasters of a given folder. this works. now I would like to add the listed rasters with drag&drop (or right-click - add) to the current map. unfortunately I don't get it to work. it doesn't throw any errors, so I have no clue what's missing... can someone help me please?
here my xaml:
        <ListView Name="FileListView" SelectionChanged="FileListView_SelectionChanged"  AllowDrop="True" Drop="FileListView_Drop" Height="Auto" Margin="0,28,0,113" Grid.Row="1">
            <ListView.View>
                <GridView>
                    <GridViewColumn Header="Filename" Width="250">
                        <GridViewColumn.CellTemplate>
                            <DataTemplate>
                                <TextBlock Text="{Binding}" />
                            </DataTemplate>
                        </GridViewColumn.CellTemplate>
                    </GridViewColumn>
                </GridView>
            </ListView.View>
        </ListView>
        <Button Content="Refresh" Click="OnRefreshButtonClicked" HorizontalAlignment="Left" Margin="0,3,0,0" Grid.Row="1" VerticalAlignment="Top"/>
here my xaml.cs:
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.Windows;
using System.Windows.Controls;
using System.Windows.Data;
using System.Windows.Documents;
using System.Windows.Input;
using System.Windows.Media;
using System.Windows.Media.Imaging;
using System.Windows.Navigation;
using System.Windows.Shapes;
using System.Collections.ObjectModel;
using System.IO;
using ArcGIS.Desktop.Framework;
using ArcGIS.Desktop.Framework.Contracts;
namespace dockpane_parcs
    /// <summary>
    /// Interaction logic for Dockpane1View.xaml
    /// </summary>
    public partial class Dockpane1View : UserControl
        private ObservableCollection<string> fileNames;
        public Dockpane1View()
            InitializeComponent();
            fileNames = new ObservableCollection<string>();
            FileListView.ItemsSource = fileNames;
            FileListView.Drop += FileListView_Drop;
        private void OnRefreshButtonClicked(object sender, RoutedEventArgs e)
            // Define the list of allowed file extensions
            string[] allowedExtensions = { ".tif", ".TIF", ".tiff", ".TIFF" };
            // Update the list of files in a folder
            string folderPath = @"C:\XXXX\YYYYY"; // Replace with your folder path
            try
                // Get a list of files with the allowed extensions from the folder
                var files = Directory.GetFiles(folderPath)
                                     .Where(file => allowedExtensions.Contains(System.IO.Path.GetExtension(file)))
                                     .ToList();
                fileNames.Clear();
                foreach (string file in files)
                    fileNames.Add(System.IO.Path.GetFileName(file));
            catch (Exception ex)
                MessageBox.Show($"Error: {ex.Message}");
        private void FileListView_Drop(object sender, DragEventArgs e)
            if (e.Data.GetDataPresent(DataFormats.FileDrop))
                // Get the dropped files as an array of strings
                string[] droppedFiles = (string[])e.Data.GetData(DataFormats.FileDrop);
                // Filter for allowed file extensions
                var validFiles = droppedFiles.Where(file => allowedExtensions.Contains(System.IO.Path.GetExtension(file)));
                // Add the valid files to the ObservableCollection
                foreach (string file in validFiles)
        private void FileListView_SelectionChanged(object sender, SelectionChangedEventArgs e)
BerendVeldkamp
Could you be a bit more specific about what exactly does not work? For instance, is the Drop event called at all?
That said, I think you need to initiate drag-drop in the MouseMove event first. See here for an example (it is for .NET Framework, but Core will probably be very similar)
nadja
Thank you for your quick response. Honestly, I'm not sure.  I don't see the mouse change from the arrow to the forbidden-sign or the arrow with the square. So I guess it's not called?
thanks for the hint with the MouseMove, but I don't get what exactly should I do with that?
BerendVeldkamp
Did you read the article I linked to? It will tell you exactly what to do
