ArcGISWebException: Error code '500'
17263
26
05-18-2015 05:55 AM
JonathanBrickey
I am intermittently getting the following exception an a ExportTileCacheTask.EstimateTileCacheSizeAsync call: Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '500' : 'Error getting status for job j76e0602d072e405eba12b24b7bba75b2 on Export Cache'
The ExportTileCacheTask.EstimateTileCacheSizeAsync call had been working without error until late last week.  There is not a lot of documentation on ArcGISWebException error codes but I am assuming internal server error.  Does anyone have any idea what may be causing this?
Jonathan
Full stack trace:
   at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__2.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
   at Esri.ArcGISRuntime.Tasks.Geoprocessing.Geoprocessor.<CheckJobStatusInternal>d__14.MoveNext()
   at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<checkTileCacheJobStatus>d__6e.MoveNext()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<CheckEstimateTileCacheSizeJobStatusAsync>d__32.MoveNext()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<checkTileCacheJobUntilCompletion>d__7d.MoveNext()
AnttiKajanus1
What service you are using and how big area (number of tiles estimate) you are requesting?
Also make sure that the service hasn't changed and it still exposes the capability.
JonathanBrickey
Service being used: https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer
Area does not seem to make a difference, as little as 1 tile all the way to the 100,000 tile max.  If I retry identical requests several times it will eventually succeed.
AnttiKajanus1
I tried the same service and it seems to work under 100 000 tile requests. If i request more than that, it gives following error. Can you check what is returned in GPMessages collection?
AnttiKajanus1
Newermind, I can repro this issue time to time. It seems that the service returns error time to time.
AnttiKajanus1
A REST request issued to ArcGIS for Server returns an HTTP status. An HTTP status of 200 means that the request has been processed. Any other HTTP status indicates that there has been a problem. For example, an HTTP status of 500 indicates an internal server error (for example, the server has gone down). Once the issue has been resolved, the client can re-issue the request.
I'll have a look if i can find what's going on.
AnttiKajanus1
We have forwarded question and reporting back here when we hear about the issue. Thanks for reporting this one.
JonathanBrickey
Thanks for your help!
JonathanBrickey
Is there an ETA on a solution to this problem?
AnttiKajanus1
We are still looking to solve this issue and will come back when I know more.
cheers,
Antti
