ArcGISWebException: Error code '500'
17242
26
05-18-2015 05:55 AM
JonathanBrickey
I am intermittently getting the following exception an a ExportTileCacheTask.EstimateTileCacheSizeAsync call: Esri.ArcGISRuntime.Http.ArcGISWebException: Error code '500' : 'Error getting status for job j76e0602d072e405eba12b24b7bba75b2 on Export Cache'
The ExportTileCacheTask.EstimateTileCacheSizeAsync call had been working without error until late last week.  There is not a lot of documentation on ArcGISWebException error codes but I am assuming internal server error.  Does anyone have any idea what may be causing this?
Jonathan
Full stack trace:
   at Esri.ArcGISRuntime.Http.ArcGISHttpClientHandler.ArcGISClientHandlerInternal.<SendAsync>d__2.MoveNext()
--- End of stack trace from previous location where exception was thrown ---
   at System.Runtime.CompilerServices.TaskAwaiter.ThrowForNonSuccess(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter.HandleNonSuccessAndDebuggerNotification(Task task)
   at System.Runtime.CompilerServices.TaskAwaiter`1.GetResult()
   at Esri.ArcGISRuntime.Tasks.Geoprocessing.Geoprocessor.<CheckJobStatusInternal>d__14.MoveNext()
   at System.Runtime.CompilerServices.ConfiguredTaskAwaitable`1.ConfiguredTaskAwaiter.GetResult()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<checkTileCacheJobStatus>d__6e.MoveNext()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<CheckEstimateTileCacheSizeJobStatusAsync>d__32.MoveNext()
   at Esri.ArcGISRuntime.Tasks.Offline.ExportTileCacheTask.<checkTileCacheJobUntilCompletion>d__7d.MoveNext()
JonathanBrickey
Confirmed the error is still occurring.
PeterRoss1
Happening still. I worked around the issue by capturing the error and just re-trying (spamming the server) until it's successful. It's not pretty but it seems to work. After working with ESRI tech support it appears the issue is in the .Net API not on the server though. If we capture the request that causes the problem in fiddler and use it to manually request it from the rest endpoint it works without the 500
PeterRoss1
...but then again, thinking about it, that could have just been the erratic nature of the errors that caused fiddler to work and the api not. I did only try once with the manual method.
JonathanBrickey
This issue seems to be resolved.  Can I get an official response verifying this?
GeirOvsttun
Looks like it
Best regards
Geir Øvsttun M.Sc
Principal Information Architect
Life Cycle Management
DNV GL - Maritime Advisory
E-mail [email protected]<mailto:[email protected]>
Mobile +47 452 49 453
www.dnvgl.com<http://www.dnvgl.com/>
AnttiKajanus1
We got confirmation from the online/content team that they made changes to fix this issue. Please let us know if you see the issue being resurfaced.
TomRippetoe
We are getting the same error response - sometimes - when using the .NET runtime version 10.2.7 to export a tile cache that is served up behind a corporate fire wall.  We haven't really been able to decipher a pattern, other than once it starts happening the regularity of the error response seems to be more frequent. Our ArcGIS Server logs show a 'Severe' entry coinciding with the error response returned to the runtime. The AGS log entry reads something like 'Error getting status for job xxxxxx on Export Cache JSONObject["value"] not found'.
Can you share what changes were made by the content team that fixed the issue when using the https://tiledbasemaps.arcgis.com/arcgis/rest/services/World_Street_Map/MapServer  service?
