Portal Named Users - Multiple Environments
5480
10-22-2020 03:43 PM
MargaretBaker
named user licensing‌
I am a little uncertain about how I can split up my ArcGIS Enterprise named user licenses between Production and Dev/Test.
I have a separate license for each of production and staging ArcGIS Enterprise and this covers the Hosting/GIS Servers in the respective environments. But, if I have 5 Creator, 10 Editor, 10 Field Worker and 200 Viewer named users, do I need to generate two separate .json files, spreading these between the environments. Why is there not an option for "staging" named users at half price as there is for the Server components?
ManuelBallesteros
Hi Margaret – Esri allows you to use the same file you used in Production for a Staging environment of Portal. You do not need to purchase extra users. If you needed any assistance doing this, you can reach out to our Technical Support staff.
Manny Ballesteros | Customer Service Team Lead
Esri | 380 New York St | Redlands, CA 92373 | USA
T 909 793 2853 x 2240 | [email protected]<mailto:[email protected]> | esri.com<http://esri.com/>
THE SCIENCE OF WHERE ®
ManuelBallesteros
Oiligriv
Ciao @ManuelBallesteros
by chance there is an official link where this is explained?
thank you
Virgilio
saraswathiemani2
"Using the same file in staging environment", is this if the staging environment is long term or it works only if it temporary environment.
