My ESRI Tech Needs Expanded Support Categories
2116
05-08-2023 05:56 AM
Status: Needs Clarification
SheriNorton
The My ESRI Support Categories and Subcategories are insufficient for both website and phone case submission. I have had many cases that do not fit at all in the limited categories/sub-categories. This is problematic, leading to delays in routing the problem to the correct analyst.
5 Comments
TeresaDolan
@SheriNorton
Thanks for your comment.
Could you supply some suggestions as to Categories and Subcategories that you were expecting to find, or that you would find useful? I can pass those on to the Support team for consideration.
SheriNorton
Sure - I had another case to submit today regarding annoying Locator errors for existing Pro Projects. In this instance, while the Customize, Configure and Develop Category is a reasonable choice, there are just two Sub-Categories (Add-Ins, Utility Network Industry Configurations). The Sub-Category is required, but neither of these limited options fits my problem at all. So I'm force to pick one of them regardless and hope the case gets routed to the correct analyst. Frustrating and inefficient.
TeresaDolan
@SheriNorton- Thanks for the details. I have passed your request on to the team that manages those lists.
SheriNorton
Hi Teresa,
Did my additional information provide sufficient details for the ESRI team? If so, can the Status be changed from Needs Clarification?  Has there been any feedback from ESRI on this topic I submitted a year ago?
TeresaDolan
@SheriNorton
If you haven't been contacted by the Support folks about your request yet, then they may need more information. I suggest visiting the Support Site at support.esri.com, and submitting this suggestion on their site so that it goes through their channels. https://support.esri.com/en-us/contact
