Using a variable in the select data tool in model builder
5867
04-08-2015 07:39 AM
alecmajor1
Hi
I'm developing a model which uses the select data tool and am trying to find a way to use this to iterate through a feature dataset. I'm stuck because the child data element does not seem to accept a variable such as %Name% only accepting a single feature class in the feature dataset.
Is there a simple way of performing this procedure or is it not possible to do this?
I've attached a jpg of the model to this message which hopefully shows what I am trying to do - iterate through a feature dataset to
a) select adjacent polygons
b) merge the adjacent polygons to the original feature class
The %name% variable is used so that the same feature class is selected for each iteration.
Hopefully someone can help!
Thanks
SepheFox
The iterate feature classes tool iterates though feature classes in a workspace. It sounds like you want iterate feature selection.
SepheFox
SepheFox
You will probably find this useful also: selecting adjacent features within a layer...
ArcGIS Desktop
curtvprice
One thing that you need to realize about model iteration is that the entire model is iterated. If you want use iterators to create a list and merge, you need to do that in a submodel. The submodel would have an iterator in it and use Collect Values to create a multivalue that would be returned as a parameter to Merge in the parent model. This is the only way to nest iteration in ModelBuilder.
Desktop 10.3 Help: Integration a model within a model > Advanced use of Model iterators
