setting preconditions for parameters
4019
06-26-2020 08:22 AM
SLouq
by MVP Alum
I have a custom tool which I built in modelbuilder and the tool works but the order of the parameters isn't the order I would like them to be in the geoprocessing window and I think this is done by setting preconditions for each parameter. However, I can't seem to find how to access the window where you can set the precondition.
Can someone tell me how to get to the window where you can set the preconditions of a parameter?
I want Input Features to appear above Input Coordinate System
DuncanHornby
MVP Notable Contributor
Scott,
You are incorrect, you do not set preconditions to change the display order of tool parameters of a model when run as a tool, you do it via the properties with drag 'n' drop.
Watch the video I made below, see how my output parameter from buffer is the first on the tool interface, I don't want that I want it at the bottom, I change the order of parameters in the model property, save, refresh and reopen the tool and you can now see it in the correct location.
Click on the image to enlarge it so its easier to watch
Reordering parameters
DuncanHornby
Scott,
SLouq
by MVP Alum
Thank you so much for the reply. I am new to ArcGIS Pro and was unfamiliar with how to set the order.
Thanks
DuncanHornby
If you feel that my reply solves your issue you should mark it as answered to help others searching for the same problem to see a valid solution was offered up.
SLouq
by MVP Alum
Thanks Duncan!
I didn't know where 'Mark as Correct' was
