naming issue after joining shapefile and xls.
1701
04-03-2024 05:39 AM
Labels (2)
SimonLake
hi there. so i have this shapefile with polygons for my country. there is a column called sub_cat with values 1 - 5838. I also have a xls. file with information regarding these sub_cat. both files have the column sub_cat with same amount values. when i try joining these together normally it works perfect and when I export the data I can see every column with original names. however i have tried doing this in model builder and when I open the exported shapefile after the join i see all the added columns but they have names corresponding to the file name. see attached photo showing this. i have tried adding the a csv file and dbf file neither work. I have this in arcmap and now in Pro. is there any way to fix this problem.Screenshot (74).jpgthis is my model for joiningScreenshot (75).jpgthis is the attribute table of the shapefile being joinedafter the join using model builderScreenshot (76).jpgthis is the attribute table after the join using model builder of the exported shapefile
DanPatterson
Are you seeing
Maintain fully qualified field names (Environment setting)—ArcGIS Pro | Documentation
which is referenced in
Add Join (Data Management)—ArcGIS Pro | Documentation
Check your environment settings in the model or consider
Join Field (Data Management)—ArcGIS Pro | Documentation
as an alternative to "add join"
... sort of retired...
DanPatterson
Are you seeing
SimonLake
i think i figured it out. I used the join field tool instead but specified the transfer method to 'use field mapping'. this seems to have worked perfectly.
DanPatterson
as suggested... it gives you better control
SimonLake
i am not sure about the first one. i am still relatively new to this. how would i see this.
when i look under environments in the add join it says no environments. not sure if this is what you meaning
