My Toolboxes Question
1584
02-14-2017 05:21 AM
ChrisHolmes
Hello all,
I'm wondering if there is a way to have more than one "My Toolboxes". Ideally I'd like to have a "My Toolboxes_D" and a "My Toolboxes_P". One pointing to a dev location, the other to a prod location.
So far to move between referencing dev and prod locations I've been editing the value of:
in the Registry Editor using the above location for my prod and the default My Toolboxes location for my dev. Just seems easier if I can have 2 My Toolboxes rather than continually going into the registry to edit that value.
Chris
Tags (1)
JayantaPoddar
Maybe you could create a toolbox (rename it and put the custom tools and scripts in it), and connect to it using Folder Connection of ArcCatalog.
Think Location
JayantaPoddar
Think Location
ChrisHolmes
Well, that might be a work around. Thanks for the idea!
Sent from my iPhone
ChrisHolmes
While this solution doesn't get at the question around the registry, I'm now using it and it works just fine and probably better in that it doesn't require mucking around with the registry. Thanks Jayanta!
