Modelbuilder - run tool dependent on user input
1142
06-26-2013 02:47 AM
KerstinServatius
I'm new to modelbuilder and I'm stucking on the following:
I need a variable that a user can type in in the tool dialog box (e.g. a value between 1 and 100). This value is not existing in any input data set.
If the value is smaller than 50 I want to run different tools than with values greater than 50.
I need a hint on how to set this up.
Thanks in advance
Jimmy
LucasDanzinger
Esri Frequent Contributor
1. Add a new variable (perhaps a Long or a String) from the Insert menu and right click > make model parameter.
2. Use If-Then_Else logic as described in this help page to determine where to go depending on the input value for the variable created in step #1.
LucasDanzinger
