Hi guys,
i would like to ask you if you can help me with modelbuilder.
1. i have two polygon shapefiles
2. i need to intersect them
3. then i need to select by attributes from the shape which was created from intersection
my problem is that when i want to connect that shape with select layer by attributes (like input) - it doesn ´t connect them.
can you please give me some advice how can i do it?
Thank you so much.
You need make feature layer infront of select layer by attribute.
