Model only works in ModelBuilder window
11393
19
03-17-2018 01:32 AM
AgataZurek
I made a model that creates a feature class, adds some fields and then enables editor tracking. I can get it to work in the ModelBuilder window but not by double clicking/opening it from the toolbox. The error I get is 000110: <target feature class> does not exist. The first two parts work just fine, it creates a feature class and adds the fields, but it comes up with that error when I include "enable editor tracking" in the model. I modified it to use the first part as a tool to chain the second part to, but I get the same error message. Please see pictures of my model for details.
I found a similar problem here: ArcGIS ModelBuilder model works in Edit windows but not from the "open" window - do you have any exp...  but the solution did not work for me.
Any help would be appreciated. Thank you.
AgataZurek
Maybe I don't understand which parameter you mean because when I tried what you are suggesting, I get the same error 000110. I have circled which parameter I think you are talking about (see below). Is that right? If so, it is not making a difference.  Also, part of the purpose of the tool is to have the name of the feature class be the same every time, I don't want it to be an option to change it.
DanPatterson_Retired
You may need to set your environment variables to 'overwriteOutputs'  I know you can do it in scripting, but at the model level I don't know.
In any event, if it exists and it can't be overwritten, then it would need to be deleted before it continues
AgataZurek
Where can I find the environment variable 'overwriteOutputs'? Also, the error is telling me it can't find the newly created feature class; how would deleting it help? Or I don't know which part you mean for me to delete.  Thanks!
AbdullahAnter
Honored Contributor
Dan is right maybe you doesn't active overwrites the outputs of geoprocessing operations..
You will find it in geoprocessinggeoprocessing options  as the following picture.
AgataZurek
I looked into the settings and it was already checked.
curtvprice
You can refresh the catalog with the Calculate Value tool with the expression arcpy.RefreshCatalog(r"%Select Geodatabase%") with Output Feature Class(4) as a precondition and the output a precondition to Enable Editor Tracking. Not so sure that would work, but it is something to try.
Another workaround I have used when a tool is giving me Model Builder parameter validation trouble is to embed the tool run in a Python function inside a Calculate Value tool code block. A pain but useful if you want to avoid creating a script tool.
AgataZurek
Thank you, that's a great idea.
AbdullahAnter
Honored Contributor
Could you move your question to https://community.esri.com/groups/model-builder to get better answers.
AgataZurek
Moved. Thank you, this was my first time posting in a long time and I had trouble finding the most appropriate place to post to.
AgataZurek
I fixed my own problem by converting the model to python and adding in a line that refreshes the catalog. Code and line that fixed it in bold near bottom. I set one parameter to name: 'Select Geodatabase' type: 'workspace'. I also made sure the output feature class was using the selected geodatabse with the feature class name I wanted to use.
# Import arcpy module
import arcpy
# Script arguments
Select_Geodatabase = arcpy.GetParameterAsText(0)
# Local variables:
Feature_Class_Name = "Geofeatures_points_SCL"
Geometry_Type = "POINT"
Coordinate_System = "PROJCS['NAD_1983_UTM_Zone_11N',GEOGCS['GCS_North_American_1983',DATUM['D_North_American_1983',SPHEROID['GRS_1980',6378137.0,298.257222101]],PRIMEM['Greenwich',0.0],UNIT['Degree',0.0174532925199433]],PROJECTION['Transverse_Mercator'],PARAMETER['False_Easting',500000.0],PARAMETER['False_Northing',0.0],PARAMETER['Central_Meridian',-117.0],PARAMETER['Scale_Factor',0.9996],PARAMETER['Latitude_Of_Origin',0.0],UNIT['Meter',1.0]];-5120900 -9998100 10000;-100000 10000;-100000 10000;0.001;0.001;0.001;IsHighPrecision"
Output_Feature_Class = Select_Geodatabase + "\" + Feature_Class_Name
Output_Feature_Class__2_ = Output_Feature_Class
Output_Feature_Class__3_ = Output_Feature_Class__2_
Output_Feature_Class__4_ = Output_Feature_Class__3_
Geofeatures_points_SCL = Output_Feature_Class__4_
# Process: Create Feature Class
arcpy.CreateFeatureclass_management(Select_Geodatabase, Feature_Class_Name, Geometry_Type, "", "DISABLED", "DISABLED", Coordinate_System, "", "0", "0", "0")
# Process: Add Field: TYPE
arcpy.AddField_management(Output_Feature_Class, "TYPE", "TEXT", "", "", "50", "", "NULLABLE", "NON_REQUIRED", "")
# Process: Add Field: LABEL
arcpy.AddField_management(Output_Feature_Class__2_, "LABEL", "TEXT", "", "", "50", "", "NULLABLE", "NON_REQUIRED", "")
# Process: Add Field: COMMENTS
arcpy.AddField_management(Output_Feature_Class__3_, "COMMENTS", "TEXT", "", "", "100", "", "NULLABLE", "NON_REQUIRED", "")
arcpy.RefreshCatalog(Select_Geodatabase)
# Process: Enable Editor Tracking
arcpy.EnableEditorTracking_management(Output_Feature_Class__4_, "", "DATE_CREATED", "", "", "ADD_FIELDS", "DATABASE_TIME")
