Model Builder need to merge results of iterator (kml to layer)
7575
05-07-2016 07:33 PM
MattCamp
I'm trying to automate a very large batch conversion of kml files. I ultimately want a single shapefile or feature class with all of the kml files info and geometry. I've got the conversion part working but getting them into a single output file is where I'm stuck. My model:
It won't let me link to the merger tool using the outputs from the iterator as the input.
I've also tried nesting the model above in a new model to then perform the merge:
Same result. Something about the kml to layer output isn't jibing. Here's a view of the output workspace of the conversion:Workspace.JPG
The names of the feature class in each GDB has been giving me problems and I guess could be the issue here.
I don't really need to save the intermediate data or files here, so if there is another route I should pursue that's fine as long as I can get all of these kmls into a single shapefile.
Matt
DanPatterson_Retired
did you see the script example in the help files which allows you to consolidate all the gdb output of the conversion to a single gdb?  If you need to stick with modelbuilder then perhaps you can consider its workflow
KML To Layer—Help | ArcGIS for Desktop
MattCamp
Dan,
Thank you for your response. I did try that script. I don't know python but was able to to get it  to do the conversion. I still couldn't get it into the merge tool automatically once the script ran.
Matt
AbdullahAnter
Honored Contributor
1- You should check shapes types (Point - polyline - polygon), you can't merge different types in single output.
2- replace Merge tool with Append Tool.
