list the attributes of a field  and then make a selection for each Python
4233
5
10-27-2014 09:28 AM
GustavoCordero
I'm using 10.2.2 Argis and I'm doing a model modelbuilder
I want to know how I can list the attributes of a field
I have shp with the field called "name" example
name |
BB
BB
AB
AB
C
C
list BB, AB, C
I want to list to make a selection for each of it
"name" = 'BB'
could help me and say how could I make this script
StevenGraf1
Add in the Select by Attributes Model.  This will let you make the Query Builder a parameter which when you select a field, click Get Unique Values and it will list all the values for that field.  You don't need to use python.
Steven
GustavoCordero
the problem is that it can be hard same field name but different attributes
GustavoCordero
example, the input can be Shp_1 with "name" attribute name field
AA
AA
BB
CC
Shp_2 with "name" attribute name field
Now with attributes
BZ
BV
BV
DanPatterson_Retired
What do you want to do with it after?  It would help guide further suggestions.
GustavoCordero
ok
I have a point layer with the "name" field
eg all the "name" AA belong to a geographical area espesifica
name |
AA
BB
CC
I want to make the selection of all AA and then use the tool "Make OD Cost Matrix Layer" of network analys
  detminiar to distance and cost between points AA
then do the same with BB, CC etc
now the problem is that the input files will not always "name" AA, BB, CC could change these
