Joining Data with model builder or python
4420
03-17-2015 11:35 AM
DanielErklauer
Where is the Join Data tool box in 10.2 for joining points to polygons based on falling inside or closest to a point?
DarrenWiens2
I'm probably miss-reading your problem, but aren't you describing a Spatial Join​? It's unclear exactly which you intend to join to which, since only a point can fall inside a polygon, and only a polygon can be closest to a point, but using 'CLOSEST' Spatial Join will provide the distance, or 0 if overlapping.
DarrenWiens2
