Iterate over rows in a shapefile in ModelBuilder?
3558
11-02-2015 09:53 PM
nataliemartinkus1
This may be a simple question (I hope).  I ran a Service Area analysis in Network Analyst and now have 1 Feature Class with 10 polys representing drive times.  I would like to iterate through the polys in the Feature Class and use each poly to clip a single landuse layer, with the output being 10 clipped landuse layers. Which Iterate tool do I use in ModelBuilder?
DanPatterson_Retired
you are using a field, the Shape field in iterators in modelbuilder​​ since a selection in a layer will be used in the process  in your case as the input as the clipping layer
