Hi there!
First off, let me just say that I feel your pain. This was (just) one of the limitations of ModelBuilder that eventually led me to embrace Python/arcpy as my solution of choice. If you're willing to go that route, you can export to a python script by editing the model and going to the Model menu > Export > to Python script. (Edit: seems like you're already aware of how to do this.)
From there, you have a couple of options. Option 1 is to set the overwriteOutput environment on your script by typing:
arcpy.env.overwriteOutput = True
at the beginning, but after importing the arcpy module.
If this fails to overwrite, you may employ a test for the existence of the feature class that you want to overwrite and if it does exist, delete it before running your conversion tool of choice. It would likely look something similar to:
# Iterate through your shapfiles with a for loop
for shp in shapefiles_to_convert:
# Get the input to the conversion tool
in_shp = shp
# Get the feature dataset where your tool will output
output_featureDataset = r"path_to_feature_dataset"
# Get the base name of your output feature class
output_name = arcpy.Describe(shp).baseName
# Test to see if the output feature class already exists
if arcpy.Exists(output_featureDataset + "\\" + output_name):
# Delete it if it does
arcpy.Delete_management(output_featureDataset + "\\" + output_name)
# Run the conversion tool
arcpy.FeatureClassToFeatureClass_conversion(shp, output_featureDataset, output_name)
I hope you find a solution to your problem!
Warm Regards,
Micah Babinski
