Create "Zip" file in Model Builder
14591
25
12-09-2021 06:38 AM
Syvertson
I have a model builder process that will create a shapefile, that later is retrieved by another process.  The other process requires a zip file input.  Is there any way I can zip up these files within model builder?
2 Solutions
curtvprice
UPDATE: added check to loop to avoid trying to write the zipfile into itself and causing an infinite loop (!) (discussed downthread)
UPDATE: this function requires the two inputs folder (path to the shapefile) and name (shapefilename, for example if your shapefile is foo.shp, the name should be foo (without the extension)
import os
import glob
import zipfile
def zipshape(folder, name):
    os.chdir(folder)
    zipname = name + ".zip"
    with zipfile.ZipFile(zipname, "w") as newzip:
        for ff in glob.glob(name + ".*"):
            if ff[-4:] != "lock" and ff != zipname:
                newzip.write(ff)
    return os.path.join(folder,zipname)
curtvprice
Improved, skipping the zip to avoid trying to write it into itself:
import os
import glob
import zipfile
    os.chdir(folder)
    flist = glob.glob(name + ".*")
        for ff in flist:
                newzip.write(ff)
    return os.path.join(folder, zipname)
ABishop
Hello Matthew,
I have a similar process but it is handled using a combination of a python script to prepare the data and then a batch file script to zip the contents of the folder.  I can share it with you if you like.
Amanda Bishop, GISP
curtvprice
You can do this using the Calculate Value tool, with a python function that uses glob and  zipfile. You may want to run Parse Path first to get the info you need to create the zip (folder, shapefile root name).
curtvprice
import os
import glob
import zipfile
    os.chdir(folder)
                newzip.write(ff)
Igor_Rosca
Good solution, solved my process. Thanks.
Syvertson
I am not yet great at python, so simple is better.  If I already know what the full path and shapefile name is always going to be, how would this look simplified?
ABishop
See below for the batch file script that I use to zip up the files. You will have to download 7Zip software to make it work.  Put this in a text file in notepad and then save it as a .bat.  I run it in Windows Task scheduler behind the script that prepares the text files.
:: Zip TxtFiles in DATA\TEXT folder
@echo ON
SET SourceDir=K:\GIS_UPDATE\DATA\TXT*.txt
SET DestDir=K:\GIS_UPDATE\DATA\TXT\MCPAEXTRACT.zip
CD /D "C:\Program Files\7-Zip"
7z.exe a "%DestDir%" "%SourceDir%"
Amanda Bishop, GISP
Syvertson
I want to stay in model builder, but if the other solution does not work, I will try this one.  Thank you for your contribution.  I am sure it will benefit someone, whether its me or another down the road.
curtvprice
Honestly I can't think of an simpler way to do this.
This is a plug and play python function, you don't need to edit it at all, just create a calculate value tool and paste the code in the code block, and make sure the variables (inside the %) match the model variables that have your folder and shapefile name. The function doesn't care as long as you give it the correct folder and shapefile root name, which is easily found with Parse Path. I suppose you could enter your folder and shapefile name directly in the Calculate Value tool expression in place the model variables...but Parse Path makes it pretty easy to avoid having to hard-code it.
Syvertson
OK.  I will try it and let you know how it goes.
