Create a model to import and merge two table
1156
10-20-2017 03:33 AM
EdoardoApollonj_Ghetti
Hello Everybody,
I'm practicing with ArcGis Pro and i want to create a model that imports an azure sql server table and a shapefile, then merges the two table and create and publish a feature layer.
Is the model builder in ArcGis Pro the right tool to achieve my goal?
How can i create this model?
Thanks!!
Mattia
DuncanHornby
MVP Notable Contributor
Suggest you read the help file ( there are plenty of examples) or get your employers to send you on a model builder course if you do not know how to constructs models.
curtvprice
MVP Alum
odraode Sometimes a good video is enough to get you started so the help will  make sense. This is a demo at DevSummit given by Dale Honeycutt‌ at few years back. ModelBuilder in Pro is very very similar to ArcMap so I think this will help you get an idea how to go about it...
Home | Esri Video Building Tools With ModelBuilder
