Batch Add Fields, Model Builder
12647
11
02-09-2015 07:00 AM
Randy_A_Stapleton
Hi All,
Can anyone suggest a better way to batch add fields using the model builder? See attached image.
ToddPayne1
You can start with the Add Field tool in a Model, right-click the tool and Make Variable - From Parameter. Field Name would be the first one you need. Open it's Properties and set to List of Values. Open the Parameter and you can do all kinds of interesting things like Insert values from a table...
Add any other Variables from Parameters as needed to accommodate different field design across fields.
HabG_
Hi Randy,
Have you tried to batch add fields by right clicking the Add Field Tool in the Data Management Tools>Fields Toolset?
TimWitt2
I think he wants it within the model builder, not doing it manually.
Randy_A_Stapleton
Yes. Within the model builder.
ToddPayne1
BlakeTerhune
I'm not too experienced with Model Builder and I didn't know about this. Thanks!
ToddPayne1
What I like is with a List of Values, you only need one Add Field tool in the Model.
Randy_A_Stapleton
Yes. I wanted to simplify my model. Thanks, Todd.
ToddPayne1
Sure thing. GeoNet is cool!
Randy_A_Stapleton
